Time Before: 0.00878 seconds
Time After: 0.01132 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01142 seconds
Time After: 0.01189 seconds
Time Before: 0.01211 seconds
Time After: 0.01225 seconds
Time Before: 0.01304 seconds
Time After: 0.01559 seconds
Time Before: 0.01232 seconds
Time After: 0.02025 seconds
Time Taken: 0.00794 seconds
Time Before: 0.02406 seconds
Time After: 0.02453 seconds
Time Before: 0.02611 seconds
Time After: 0.02738 seconds
Time Before: 0.02338 seconds
Time After: 0.02766 seconds
Time Taken: 0.00429 seconds
Time Before: 0.04898 seconds
Time After: 0.04919 seconds
Time Before: 0.05854 seconds
Time After: 0.05990 seconds
Time Taken: 0.00136 seconds
Time Before: 0.06713 seconds
Time After: 0.06732 seconds
Time Before: 0.07105 seconds
Time After: 0.07252 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107478', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.09047 seconds
Time After: 0.09078 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
