Time Before: 0.00134 seconds
Time After: 0.00182 seconds
Time Before: 0.00189 seconds
Time After: 0.00248 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00277 seconds
Time After: 0.00299 seconds
Time Before: 0.00366 seconds
Time After: 0.00617 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00306 seconds
Time After: 0.00957 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01141 seconds
Time After: 0.01167 seconds
Time Before: 0.01422 seconds
Time After: 0.01543 seconds
Time Before: 0.01081 seconds
Time After: 0.01560 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02089 seconds
Time After: 0.02102 seconds
Time Before: 0.02271 seconds
Time After: 0.02392 seconds
End call of global.php: 0.025498867034912
Time Before: 0.02670 seconds
Time After: 0.02692 seconds
Time Before: 0.02892 seconds
Time After: 0.03036 seconds
SET lastactivity = 1776615214, location = '/forums/private.php?do=newpm&explain=1&u=107495'
Time Before: 0.04257 seconds
Time After: 0.04290 seconds
Page generated in 0.041689872741699 seconds with 9 queries, spending 0.008143424987793 doing MySQL queries and 0.033546447753906 doing PHP things.
