Time Before: 0.01170 seconds
Time After: 0.02342 seconds
Time Taken: 0.01172 seconds
Time Before: 0.02351 seconds
Time After: 0.02392 seconds
Time Before: 0.02411 seconds
Time After: 0.02425 seconds
Time Before: 0.02500 seconds
Time After: 0.02714 seconds
Time Taken: 0.00214 seconds
Time Before: 0.02432 seconds
Time After: 0.03140 seconds
Time Taken: 0.00708 seconds
Time Before: 0.04253 seconds
Time After: 0.04294 seconds
Time Before: 0.04495 seconds
Time After: 0.04611 seconds
Time Taken: 0.00116 seconds
Time Before: 0.04181 seconds
Time After: 0.04631 seconds
Time Taken: 0.00450 seconds
Time Before: 0.07257 seconds
Time After: 0.07266 seconds
Time Taken: 0.00009 seconds
Time Before: 0.09764 seconds
Time After: 0.09888 seconds
Time Before: 0.11462 seconds
Time After: 0.11475 seconds
Time Before: 0.11709 seconds
Time After: 0.11862 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107524', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.13982 seconds
Time After: 0.14010 seconds
