Time Before: 0.02428 seconds
Time After: 0.03136 seconds
Time Taken: 0.00708 seconds
Time Before: 0.03147 seconds
Time After: 0.03192 seconds
Time Before: 0.03222 seconds
Time After: 0.03237 seconds
Time Before: 0.03322 seconds
Time After: 0.03596 seconds
Time Taken: 0.00274 seconds
Time Before: 0.03243 seconds
Time After: 0.03982 seconds
Time Taken: 0.00739 seconds
Time Before: 0.05033 seconds
Time After: 0.05075 seconds
Time Before: 0.05420 seconds
Time After: 0.05544 seconds
Time Before: 0.04957 seconds
Time After: 0.05563 seconds
Time Taken: 0.00606 seconds
Time Before: 0.09359 seconds
Time After: 0.09372 seconds
Time Before: 0.10791 seconds
Time After: 0.10917 seconds
Time Before: 0.11863 seconds
Time After: 0.11879 seconds
Time Before: 0.12103 seconds
Time After: 0.12246 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107573', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.14070 seconds
Time After: 0.14112 seconds
