Time Before: 0.02298 seconds
Time After: 0.02963 seconds
Time Taken: 0.00665 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02971 seconds
Time After: 0.03053 seconds
Time Taken: 0.00082 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03084 seconds
Time After: 0.03171 seconds
Time Taken: 0.00087 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03247 seconds
Time After: 0.03571 seconds
Time Taken: 0.00324 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03179 seconds
Time After: 0.04032 seconds
Time Taken: 0.00853 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04951 seconds
Time After: 0.05004 seconds
Time Taken: 0.00053 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05255 seconds
Time After: 0.05380 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04873 seconds
Time After: 0.05406 seconds
Time Taken: 0.00534 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.09774 seconds
Time After: 0.09790 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.15037 seconds
Time After: 0.15167 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.17885 seconds
Time After: 0.17903 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.18401 seconds
Time After: 0.18547 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107576', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.20704 seconds
Time After: 0.20733 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
