Time Before: 0.00346 seconds
Time After: 0.00568 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00578 seconds
Time After: 0.00616 seconds
Time Before: 0.00637 seconds
Time After: 0.00648 seconds
Time Before: 0.00730 seconds
Time After: 0.00989 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00655 seconds
Time After: 0.01581 seconds
Time Taken: 0.00926 seconds
Time Before: 0.02026 seconds
Time After: 0.02064 seconds
Time Before: 0.02314 seconds
Time After: 0.02438 seconds
Time Before: 0.01948 seconds
Time After: 0.02466 seconds
Time Taken: 0.00518 seconds
Time Before: 0.03740 seconds
Time After: 0.03756 seconds
Time Before: 0.04554 seconds
Time After: 0.04756 seconds
Time Taken: 0.00202 seconds
Time Before: 0.05337 seconds
Time After: 0.05377 seconds
Time Before: 0.05625 seconds
Time After: 0.05787 seconds
Time Taken: 0.00162 seconds
UPDATE session SET lastactivity = 1789016051, location = '/forums/private.php?do=newpm&explain=1&u=107679' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07782 seconds
Time After: 0.07824 seconds
