Time Before: 0.02054 seconds
Time After: 0.02601 seconds
Time Taken: 0.00547 seconds
Time Before: 0.02612 seconds
Time After: 0.02655 seconds
Time Before: 0.02683 seconds
Time After: 0.02701 seconds
Time Before: 0.02788 seconds
Time After: 0.03067 seconds
Time Taken: 0.00279 seconds
Time Before: 0.02709 seconds
Time After: 0.03595 seconds
Time Taken: 0.00885 seconds
Time Before: 0.04223 seconds
Time After: 0.04264 seconds
Time Before: 0.04515 seconds
Time After: 0.04640 seconds
Time Before: 0.04154 seconds
Time After: 0.04664 seconds
Time Taken: 0.00510 seconds
Time Before: 0.07956 seconds
Time After: 0.07972 seconds
Time Before: 0.09266 seconds
Time After: 0.09390 seconds
Time Before: 0.10182 seconds
Time After: 0.10198 seconds
Time Before: 0.10483 seconds
Time After: 0.10711 seconds
Time Taken: 0.00228 seconds
UPDATE session SET lastactivity = 1776534377, location = '/forums/private.php?do=newpm&explain=1&u=107685', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.12889 seconds
Time After: 0.12915 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
