Time Before: 0.02171 seconds
Time After: 0.03110 seconds
Time Taken: 0.00939 seconds
Time Before: 0.03121 seconds
Time After: 0.03166 seconds
Time Before: 0.03198 seconds
Time After: 0.03214 seconds
Time Before: 0.03298 seconds
Time After: 0.03568 seconds
Time Taken: 0.00271 seconds
Time Before: 0.03222 seconds
Time After: 0.04162 seconds
Time Taken: 0.00940 seconds
Time Before: 0.05345 seconds
Time After: 0.05387 seconds
Time Before: 0.05680 seconds
Time After: 0.05808 seconds
Time Before: 0.05267 seconds
Time After: 0.05832 seconds
Time Taken: 0.00565 seconds
Time Before: 0.10072 seconds
Time After: 0.10090 seconds
Time Before: 0.12116 seconds
Time After: 0.12240 seconds
End call of global.php: 0.12449216842651
Time Before: 0.13241 seconds
Time After: 0.13261 seconds
Time Before: 0.13528 seconds
Time After: 0.13679 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=10769'
Time Before: 0.15791 seconds
Time After: 0.15827 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.15683698654175 seconds with 9 queries, spending 0.0085058212280273 doing MySQL queries and 0.14833116531372 doing PHP things.
