Time Before: 0.00165 seconds
Time After: 0.00242 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00252 seconds
Time After: 0.00292 seconds
Time Before: 0.00317 seconds
Time After: 0.00333 seconds
Time Before: 0.00412 seconds
Time After: 0.00884 seconds
Time Taken: 0.00473 seconds
Time Before: 0.00342 seconds
Time After: 0.01236 seconds
Time Taken: 0.00894 seconds
Time Before: 0.01427 seconds
Time After: 0.01466 seconds
Time Before: 0.01614 seconds
Time After: 0.01737 seconds
Time Before: 0.01355 seconds
Time After: 0.01762 seconds
Time Taken: 0.00407 seconds
Time Before: 0.02380 seconds
Time After: 0.02394 seconds
Time Before: 0.02606 seconds
Time After: 0.02732 seconds
End call of global.php: 0.029464960098267
Time Before: 0.03084 seconds
Time After: 0.03099 seconds
Time Before: 0.03395 seconds
Time After: 0.03541 seconds
SET lastactivity = 1773216913, location = '/forums/private.php?do=newpm&explain=1&u=107694'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04883 seconds
Time After: 0.04912 seconds
Page generated in 0.047905921936035 seconds with 9 queries, spending 0.01022481918335 doing MySQL queries and 0.037681102752686 doing PHP things.
