Time Before: 0.02185 seconds
Time After: 0.02924 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02935 seconds
Time After: 0.02980 seconds
Time Before: 0.03011 seconds
Time After: 0.03030 seconds
Time Before: 0.03109 seconds
Time After: 0.03614 seconds
Time Taken: 0.00506 seconds
Time Before: 0.03037 seconds
Time After: 0.04061 seconds
Time Taken: 0.01025 seconds
Time Before: 0.05176 seconds
Time After: 0.05221 seconds
Time Before: 0.05477 seconds
Time After: 0.05621 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05098 seconds
Time After: 0.05643 seconds
Time Taken: 0.00546 seconds
Memory After: 2,261.703 KB
Time Before: 0.09984 seconds
Time After: 0.10000 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.12170 seconds
Time After: 0.12314 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.12626600265503
Time Before: 0.13284 seconds
Time After: 0.13301 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13574 seconds
Time After: 0.13720 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107700'
Time Before: 0.15687 seconds
Time After: 0.15713 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.1556670665741 seconds with 9 queries, spending 0.011080265045166 doing MySQL queries and 0.14458680152893 doing PHP things.
