Time Before: 0.00154 seconds
Time After: 0.00204 seconds
Time Before: 0.00211 seconds
Time After: 0.00260 seconds
Time Before: 0.00283 seconds
Time After: 0.00294 seconds
Time Before: 0.00361 seconds
Time After: 0.00644 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00299 seconds
Time After: 0.01102 seconds
Time Taken: 0.00804 seconds
Time Before: 0.01279 seconds
Time After: 0.01317 seconds
Time Before: 0.01568 seconds
Time After: 0.01689 seconds
Time Before: 0.01222 seconds
Time After: 0.01707 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02219 seconds
Time After: 0.02233 seconds
Time Before: 0.02420 seconds
Time After: 0.02545 seconds
End call of global.php: 0.027117967605591
Time Before: 0.02841 seconds
Time After: 0.02854 seconds
Time Before: 0.03048 seconds
Time After: 0.03190 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107735'
Time Before: 0.04457 seconds
Time After: 0.04481 seconds
Page generated in 0.043630123138428 seconds with 9 queries, spending 0.0082070827484131 doing MySQL queries and 0.035423040390015 doing PHP things.
