Time Before: 0.00255 seconds
Time After: 0.00312 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00319 seconds
Time After: 0.00368 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00387 seconds
Time After: 0.00401 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00484 seconds
Time After: 0.00721 seconds
Time Taken: 0.00236 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00405 seconds
Time After: 0.01206 seconds
Time Taken: 0.00801 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01463 seconds
Time After: 0.01499 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01776 seconds
Time After: 0.01902 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01385 seconds
Time After: 0.01933 seconds
Time Taken: 0.00547 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02652 seconds
Time After: 0.02664 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03595 seconds
Time After: 0.03715 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.038954973220825
Time Before: 0.04634 seconds
Time After: 0.04657 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04933 seconds
Time After: 0.05102 seconds
Time Taken: 0.00169 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107755', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.06431 seconds
Time After: 0.06472 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
Page generated in 0.063383102416992 seconds with 9 queries, spending 0.0082352161407471 doing MySQL queries and 0.055147886276245 doing PHP things.
