Time Before: 0.00140 seconds
Time After: 0.00186 seconds
Time Before: 0.00208 seconds
Time After: 0.00268 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00292 seconds
Time After: 0.00311 seconds
Time Before: 0.00381 seconds
Time After: 0.00642 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00316 seconds
Time After: 0.00984 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01157 seconds
Time After: 0.01197 seconds
Time Before: 0.01435 seconds
Time After: 0.01553 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01101 seconds
Time After: 0.01569 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02062 seconds
Time After: 0.02077 seconds
Time Before: 0.02268 seconds
Time After: 0.02391 seconds
End call of global.php: 0.025572061538696
Time Before: 0.02673 seconds
Time After: 0.02693 seconds
Time Before: 0.02887 seconds
Time After: 0.03039 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107760'
Time Before: 0.04307 seconds
Time After: 0.04346 seconds
Page generated in 0.042159080505371 seconds with 9 queries, spending 0.0084657669067383 doing MySQL queries and 0.033693313598633 doing PHP things.
