Time Before: 0.00186 seconds
Time After: 0.00241 seconds
Time Taken: 0.00055 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00250 seconds
Time After: 0.00294 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00322 seconds
Time After: 0.00335 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00416 seconds
Time After: 0.00691 seconds
Time Taken: 0.00275 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00341 seconds
Time After: 0.01139 seconds
Time Taken: 0.00798 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.01421 seconds
Time After: 0.01462 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.01755 seconds
Time After: 0.01891 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,148.906 KB
Memory After: 2,148.766 KB
Time Before: 0.01360 seconds
Time After: 0.01910 seconds
Time Taken: 0.00550 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.789 KB
Time Before: 0.02646 seconds
Time After: 0.02666 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02855 seconds
Time After: 0.02976 seconds
Memory Before: 2,903.656 KB
Memory After: 2,904.250 KB
End call of global.php: 0.031438827514648
Time Before: 0.03273 seconds
Time After: 0.03287 seconds
Memory Before: 3,540.422 KB
Memory After: 3,540.852 KB
Time Before: 0.03496 seconds
Time After: 0.03654 seconds
Time Taken: 0.00158 seconds
Memory Before: 3,821.953 KB
Memory After: 3,823.641 KB
SET lastactivity = 1785311515, location = '/forums/private.php?do=newpm&explain=1&u=107761'
Time Before: 0.05149 seconds
Time After: 0.05199 seconds
Memory Before: 4,295.914 KB
Memory After: 4,296.141 KB
Page generated in 0.050599813461304 seconds with 9 queries, spending 0.0087311267852783 doing MySQL queries and 0.041868686676025 doing PHP things.
