Time Before: 0.00313 seconds
Time After: 0.00389 seconds
Time Taken: 0.00076 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00399 seconds
Time After: 0.00446 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00471 seconds
Time After: 0.00485 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00570 seconds
Time After: 0.00891 seconds
Time Taken: 0.00321 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00493 seconds
Time After: 0.01227 seconds
Time Taken: 0.00734 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01421 seconds
Time After: 0.01457 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01710 seconds
Time After: 0.01838 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01362 seconds
Time After: 0.01862 seconds
Time Taken: 0.00500 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02701 seconds
Time After: 0.02714 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03443 seconds
Time After: 0.03590 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.04703 seconds
Time After: 0.04722 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04959 seconds
Time After: 0.05109 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107769', badlocation = 1 WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.06657 seconds
Time After: 0.06681 seconds
Memory Before: 5,998.641 KB
Memory After: 5,998.859 KB
