Time Before: 0.01228 seconds
Time After: 0.01875 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01889 seconds
Time After: 0.01931 seconds
Time Before: 0.01956 seconds
Time After: 0.01970 seconds
Time Before: 0.02062 seconds
Time After: 0.02275 seconds
Time Taken: 0.00213 seconds
Time Before: 0.01978 seconds
Time After: 0.02803 seconds
Time Taken: 0.00825 seconds
Time Before: 0.03528 seconds
Time After: 0.03570 seconds
Time Before: 0.03899 seconds
Time After: 0.04018 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03459 seconds
Time After: 0.04041 seconds
Time Taken: 0.00582 seconds
Memory After: 2,261.820 KB
Time Before: 0.05848 seconds
Time After: 0.05861 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07448 seconds
Time After: 0.07573 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08299 seconds
Time After: 0.08314 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08550 seconds
Time After: 0.08694 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789123911, location = '/forums/private.php?do=newpm&explain=1&u=107782' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10688 seconds
Time After: 0.10722 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
