Time Before: 0.01063 seconds
Time After: 0.01383 seconds
Time Taken: 0.00319 seconds
Time Before: 0.01390 seconds
Time After: 0.01431 seconds
Time Before: 0.01458 seconds
Time After: 0.01471 seconds
Time Before: 0.01546 seconds
Time After: 0.01775 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01479 seconds
Time After: 0.02237 seconds
Time Taken: 0.00758 seconds
Time Before: 0.02699 seconds
Time After: 0.02737 seconds
Time Before: 0.03018 seconds
Time After: 0.03141 seconds
Time Before: 0.02621 seconds
Time After: 0.03168 seconds
Time Taken: 0.00547 seconds
Time Before: 0.05139 seconds
Time After: 0.05157 seconds
Time Before: 0.06048 seconds
Time After: 0.06179 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.063903093338013
Time Before: 0.06692 seconds
Time After: 0.06710 seconds
Time Before: 0.06957 seconds
Time After: 0.07101 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107815'
Time Before: 0.08749 seconds
Time After: 0.08777 seconds
Page generated in 0.086338996887207 seconds with 9 queries, spending 0.0078589916229248 doing MySQL queries and 0.078480005264282 doing PHP things.
