Time Before: 0.01429 seconds
Time After: 0.01788 seconds
Time Taken: 0.00360 seconds
Time Before: 0.01798 seconds
Time After: 0.01850 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01874 seconds
Time After: 0.01886 seconds
Time Before: 0.01986 seconds
Time After: 0.02209 seconds
Time Taken: 0.00224 seconds
Time Before: 0.01892 seconds
Time After: 0.02617 seconds
Time Taken: 0.00725 seconds
Time Before: 0.03435 seconds
Time After: 0.03476 seconds
Time Before: 0.03805 seconds
Time After: 0.03940 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03360 seconds
Time After: 0.03963 seconds
Time Taken: 0.00604 seconds
Memory After: 2,261.820 KB
Time Before: 0.06025 seconds
Time After: 0.06042 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07358 seconds
Time After: 0.07482 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08407 seconds
Time After: 0.08421 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08677 seconds
Time After: 0.08912 seconds
Time Taken: 0.00234 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788972589, location = '/forums/private.php?do=newpm&explain=1&u=107820', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10678 seconds
Time After: 0.10719 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
