Time Before: 0.01023 seconds
Time After: 0.01519 seconds
Time Taken: 0.00495 seconds
Time Before: 0.01529 seconds
Time After: 0.01572 seconds
Time Before: 0.01595 seconds
Time After: 0.01610 seconds
Time Before: 0.01693 seconds
Time After: 0.01943 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01617 seconds
Time After: 0.02411 seconds
Time Taken: 0.00794 seconds
Time Before: 0.03125 seconds
Time After: 0.03205 seconds
Time Taken: 0.00080 seconds
Time Before: 0.03408 seconds
Time After: 0.03527 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03058 seconds
Time After: 0.03553 seconds
Memory After: 2,261.820 KB
Time Before: 0.05397 seconds
Time After: 0.05415 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.16408 seconds
Time After: 0.16548 seconds
Time Taken: 0.00140 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.16798782348633
Time Before: 0.17490 seconds
Time After: 0.17529 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.17851 seconds
Time After: 0.17999 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789034643, location = '/forums/private.php?do=newpm&explain=1&u=107851', badlocation = 1
Time Before: 0.19641 seconds
Time After: 0.19671 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.19537997245789 seconds with 9 queries, spending 0.0088112354278564 doing MySQL queries and 0.18656873703003 doing PHP things.
