Time Before: 0.00175 seconds
Time After: 0.00247 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00258 seconds
Time After: 0.00301 seconds
Time Before: 0.00320 seconds
Time After: 0.00333 seconds
Time Before: 0.00410 seconds
Time After: 0.00672 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00341 seconds
Time After: 0.01037 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01247 seconds
Time After: 0.01294 seconds
Time Before: 0.01621 seconds
Time After: 0.01839 seconds
Time Taken: 0.00218 seconds
Time Before: 0.01167 seconds
Time After: 0.01864 seconds
Time Before: 0.02410 seconds
Time After: 0.02426 seconds
Time Before: 0.02692 seconds
Time After: 0.02847 seconds
Time Taken: 0.00155 seconds
End call of global.php: 0.030139923095703
Time Before: 0.03141 seconds
Time After: 0.03158 seconds
Time Before: 0.03364 seconds
Time After: 0.03511 seconds
SET lastactivity = 1789082433, location = '/forums/private.php?do=newpm&explain=1&u=107858'
Time Before: 0.05059 seconds
Time After: 0.05091 seconds
Page generated in 0.049643993377686 seconds with 9 queries, spending 0.0095067024230957 doing MySQL queries and 0.04013729095459 doing PHP things.
