Time Before: 0.01140 seconds
Time After: 0.01550 seconds
Time Taken: 0.00410 seconds
Time Before: 0.01558 seconds
Time After: 0.01616 seconds
Time Taken: 0.00058 seconds
Time Before: 0.01643 seconds
Time After: 0.01654 seconds
Time Before: 0.01733 seconds
Time After: 0.01946 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01661 seconds
Time After: 0.02355 seconds
Time Taken: 0.00694 seconds
Time Before: 0.02781 seconds
Time After: 0.02813 seconds
Time Before: 0.03026 seconds
Time After: 0.03149 seconds
Time Before: 0.02713 seconds
Time After: 0.03167 seconds
Time Taken: 0.00454 seconds
Time Before: 0.05064 seconds
Time After: 0.05079 seconds
Time Before: 2.51779 seconds
Time After: 2.51936 seconds
Time Taken: 0.00158 seconds
End call of global.php: 2.5224130153656
Time Before: 2.53281 seconds
Time After: 2.53300 seconds
Time Before: 2.53598 seconds
Time After: 2.53812 seconds
SET lastactivity = 1788937021, location = '/forums/private.php?do=newpm&explain=1&u=107866', badlocation = 1
Time Before: 2.55884 seconds
Time After: 2.55917 seconds
Page generated in 2.5576720237732 seconds with 9 queries, spending 0.0087518692016602 doing MySQL queries and 2.5489201545715 doing PHP things.
