Time Before: 0.00209 seconds
Time After: 0.00270 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00281 seconds
Time After: 0.00342 seconds
Time Before: 0.00371 seconds
Time After: 0.00385 seconds
Time Before: 0.00452 seconds
Time After: 0.00735 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00391 seconds
Time After: 0.01161 seconds
Time Taken: 0.00770 seconds
Time Before: 0.01398 seconds
Time After: 0.01445 seconds
Time Before: 0.01722 seconds
Time After: 0.01842 seconds
Time Before: 0.01322 seconds
Time After: 0.01868 seconds
Time Taken: 0.00546 seconds
Time Before: 0.02429 seconds
Time After: 0.02444 seconds
Time Before: 0.02688 seconds
Time After: 0.02813 seconds
End call of global.php: 0.030472040176392
Time Before: 0.03206 seconds
Time After: 0.03229 seconds
Time Before: 0.03428 seconds
Time After: 0.03576 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107896', badlocation = 1
Time Before: 0.04871 seconds
Time After: 0.04901 seconds
Page generated in 0.047806024551392 seconds with 9 queries, spending 0.0086519718170166 doing MySQL queries and 0.039154052734375 doing PHP things.
