Time Before: 0.00150 seconds
Time After: 0.00206 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00213 seconds
Time After: 0.00264 seconds
Time Before: 0.00289 seconds
Time After: 0.00303 seconds
Time Before: 0.00393 seconds
Time After: 0.00681 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00310 seconds
Time After: 0.01046 seconds
Time Taken: 0.00736 seconds
Time Before: 0.01404 seconds
Time After: 0.01455 seconds
Time Before: 0.01752 seconds
Time After: 0.01880 seconds
Time Before: 0.01254 seconds
Time After: 0.01899 seconds
Time Taken: 0.00644 seconds
Time Before: 0.02428 seconds
Time After: 0.02444 seconds
Time Before: 0.02660 seconds
Time After: 0.02787 seconds
End call of global.php: 0.029624938964844
Time Before: 0.03081 seconds
Time After: 0.03099 seconds
Time Before: 0.03311 seconds
Time After: 0.03464 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1785386409, location = '/forums/private.php?do=newpm&explain=1&u=10790'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05081 seconds
Time After: 0.05155 seconds
Time Taken: 0.00074 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049888849258423 seconds with 9 queries, spending 0.0091981887817383 doing MySQL queries and 0.040690660476685 doing PHP things.
