Time Before: 0.00139 seconds
Time After: 0.00182 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00190 seconds
Time After: 0.00235 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00265 seconds
Time After: 0.00286 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00356 seconds
Time After: 0.00580 seconds
Time Taken: 0.00224 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00291 seconds
Time After: 0.01075 seconds
Time Taken: 0.00784 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01322 seconds
Time After: 0.01362 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01680 seconds
Time After: 0.01798 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01240 seconds
Time After: 0.01823 seconds
Time Taken: 0.00584 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02468 seconds
Time After: 0.02480 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02713 seconds
Time After: 0.02834 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.029951095581055
Time Before: 0.03147 seconds
Time After: 0.03160 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03364 seconds
Time After: 0.03506 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107910'
Time Before: 0.05322 seconds
Time After: 0.05351 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.052097082138062 seconds with 9 queries, spending 0.0076823234558105 doing MySQL queries and 0.044414758682251 doing PHP things.
