Time Before: 0.00980 seconds
Time After: 0.01369 seconds
Time Taken: 0.00389 seconds
Time Before: 0.01379 seconds
Time After: 0.01421 seconds
Time Before: 0.01449 seconds
Time After: 0.01462 seconds
Time Before: 0.01540 seconds
Time After: 0.01767 seconds
Time Taken: 0.00227 seconds
Time Before: 0.01470 seconds
Time After: 0.02242 seconds
Time Taken: 0.00773 seconds
Time Before: 0.02677 seconds
Time After: 0.02715 seconds
Time Before: 0.02990 seconds
Time After: 0.03107 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02609 seconds
Time After: 0.03131 seconds
Time Taken: 0.00522 seconds
Time Before: 0.04992 seconds
Time After: 0.05004 seconds
Time Before: 0.05897 seconds
Time After: 0.06018 seconds
End call of global.php: 0.062124013900757
Time Before: 0.06486 seconds
Time After: 0.06499 seconds
Time Before: 0.06728 seconds
Time After: 0.06881 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1785288795, location = '/forums/private.php?do=newpm&explain=1&u=107913'
Time Before: 0.08839 seconds
Time After: 0.08871 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.086963176727295 seconds with 9 queries, spending 0.0076794624328613 doing MySQL queries and 0.079283714294434 doing PHP things.
