Time Before: 0.00190 seconds
Time After: 0.00247 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00257 seconds
Time After: 0.00298 seconds
Time Before: 0.00320 seconds
Time After: 0.00340 seconds
Time Before: 0.00432 seconds
Time After: 0.00656 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00348 seconds
Time After: 0.01157 seconds
Time Taken: 0.00810 seconds
Time Before: 0.01353 seconds
Time After: 0.01409 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01731 seconds
Time After: 0.01876 seconds
Time Before: 0.01277 seconds
Time After: 0.01893 seconds
Time Taken: 0.00616 seconds
Time Before: 0.02482 seconds
Time After: 0.02493 seconds
Time Before: 0.02679 seconds
Time After: 0.02799 seconds
End call of global.php: 0.029711008071899
Time Before: 0.03103 seconds
Time After: 0.03123 seconds
Time Before: 0.03354 seconds
Time After: 0.03494 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1789129831, location = '/forums/private.php?do=newpm&explain=1&u=107920'
Time Before: 0.04755 seconds
Time After: 0.04785 seconds
Page generated in 0.046653985977173 seconds with 9 queries, spending 0.0080749988555908 doing MySQL queries and 0.038578987121582 doing PHP things.
