Time Before: 0.02174 seconds
Time After: 0.02952 seconds
Time Taken: 0.00778 seconds
Time Before: 0.02964 seconds
Time After: 0.03172 seconds
Time Taken: 0.00208 seconds
Time Before: 0.03203 seconds
Time After: 0.03237 seconds
Time Before: 0.03357 seconds
Time After: 0.03678 seconds
Time Taken: 0.00321 seconds
Time Before: 0.03246 seconds
Time After: 0.04255 seconds
Time Taken: 0.01009 seconds
Time Before: 0.05374 seconds
Time After: 0.05412 seconds
Time Before: 0.05678 seconds
Time After: 0.05801 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05307 seconds
Time After: 0.05828 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.703 KB
Time Before: 0.10571 seconds
Time After: 0.10588 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.12474 seconds
Time After: 0.12596 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.14108 seconds
Time After: 0.14127 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.14450 seconds
Time After: 0.14599 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=107930' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.16612 seconds
Time After: 0.16635 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
