Time Before: 0.01295 seconds
Time After: 0.01926 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01936 seconds
Time After: 0.01986 seconds
Time Before: 0.02009 seconds
Time After: 0.02025 seconds
Time Before: 0.02116 seconds
Time After: 0.02346 seconds
Time Taken: 0.00230 seconds
Time Before: 0.02033 seconds
Time After: 0.02792 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03427 seconds
Time After: 0.03481 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03859 seconds
Time After: 0.04037 seconds
Time Taken: 0.00178 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03357 seconds
Time After: 0.04059 seconds
Time Taken: 0.00703 seconds
Memory After: 2,261.703 KB
Time Before: 0.06192 seconds
Time After: 0.06206 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07612 seconds
Time After: 0.07842 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.080936908721924
Time Before: 0.08770 seconds
Time After: 0.08790 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.09107 seconds
Time After: 0.09391 seconds
Time Taken: 0.00284 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=107937'
Time Before: 0.11507 seconds
Time After: 0.23306 seconds
Time Taken: 0.11799 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.11407995223999 seconds with 9 queries, spending 0.12876200675964 doing MySQL queries and -0.014682054519653 doing PHP things.
