Time Before: 0.02872 seconds
Time After: 0.03443 seconds
Time Taken: 0.00571 seconds
Time Before: 0.03450 seconds
Time After: 0.03497 seconds
Time Before: 0.03518 seconds
Time After: 0.03530 seconds
Time Before: 0.03598 seconds
Time After: 0.03785 seconds
Time Taken: 0.00186 seconds
Time Before: 0.03535 seconds
Time After: 0.04176 seconds
Time Taken: 0.00641 seconds
Time Before: 0.05053 seconds
Time After: 0.05095 seconds
Time Before: 0.05254 seconds
Time After: 0.05375 seconds
Time Before: 0.04995 seconds
Time After: 0.05399 seconds
Time Taken: 0.00404 seconds
Time Before: 0.10276 seconds
Time After: 0.10297 seconds
Time Before: 0.12124 seconds
Time After: 0.12250 seconds
End call of global.php: 0.12449193000793
Time Before: 0.13386 seconds
Time After: 0.13407 seconds
Time Before: 0.13692 seconds
Time After: 0.13843 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=107954'
Time Before: 0.15773 seconds
Time After: 0.15799 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.15664887428284 seconds with 9 queries, spending 0.0075383186340332 doing MySQL queries and 0.1491105556488 doing PHP things.
