Time Before: 0.02673 seconds
Time After: 0.03243 seconds
Time Taken: 0.00570 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.03253 seconds
Time After: 0.03299 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03326 seconds
Time After: 0.03340 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.03411 seconds
Time After: 0.03680 seconds
Time Taken: 0.00269 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03348 seconds
Time After: 0.04127 seconds
Time Taken: 0.00779 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.05138 seconds
Time After: 0.05181 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05440 seconds
Time After: 0.05561 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.05070 seconds
Time After: 0.05588 seconds
Time Taken: 0.00517 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.10137 seconds
Time After: 0.10156 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.11899 seconds
Time After: 0.12021 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
Time Before: 0.13076 seconds
Time After: 0.13093 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.13357 seconds
Time After: 0.13514 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
UPDATE session SET lastactivity = 1776984998, location = '/forums/private.php?do=newpm&explain=1&u=107979', badlocation = 1 WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.15382 seconds
Time After: 0.15412 seconds
Memory Before: 4,299.438 KB
Memory After: 4,299.648 KB
