Time Before: 0.01962 seconds
Time After: 0.02913 seconds
Time Taken: 0.00951 seconds
Time Before: 0.02922 seconds
Time After: 0.02960 seconds
Time Before: 0.02986 seconds
Time After: 0.02999 seconds
Time Before: 0.03074 seconds
Time After: 0.03337 seconds
Time Taken: 0.00263 seconds
Time Before: 0.03006 seconds
Time After: 0.03776 seconds
Time Taken: 0.00770 seconds
Time Before: 0.04782 seconds
Time After: 0.04822 seconds
Time Before: 0.05086 seconds
Time After: 0.05204 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04720 seconds
Time After: 0.05223 seconds
Time Taken: 0.00502 seconds
Time Before: 0.08479 seconds
Time After: 0.08493 seconds
Time Before: 0.11142 seconds
Time After: 0.11267 seconds
End call of global.php: 0.1151909828186
Time Before: 0.12356 seconds
Time After: 0.12372 seconds
Time Before: 0.12632 seconds
Time After: 0.12774 seconds
SET lastactivity = 1785383978, location = '/forums/private.php?do=newpm&explain=1&u=108009', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.14978 seconds
Time After: 0.15009 seconds
Page generated in 0.1487729549408 seconds with 9 queries, spending 0.0080094337463379 doing MySQL queries and 0.14076352119446 doing PHP things.
