Time Before: 0.02437 seconds
Time After: 0.03020 seconds
Time Taken: 0.00583 seconds
Time Before: 0.03027 seconds
Time After: 0.03068 seconds
Time Before: 0.03091 seconds
Time After: 0.03103 seconds
Time Before: 0.03173 seconds
Time After: 0.03445 seconds
Time Taken: 0.00272 seconds
Time Before: 0.03110 seconds
Time After: 0.03828 seconds
Time Taken: 0.00718 seconds
Time Before: 0.04835 seconds
Time After: 0.04876 seconds
Time Before: 0.05110 seconds
Time After: 0.05242 seconds
Time Taken: 0.00132 seconds
Time Before: 0.04771 seconds
Time After: 0.05265 seconds
Time Taken: 0.00495 seconds
Time Before: 0.08569 seconds
Time After: 0.08590 seconds
Time Before: 0.35099 seconds
Time After: 0.35246 seconds
End call of global.php: 0.3547580242157
Time Before: 0.36262 seconds
Time After: 0.36282 seconds
Time Before: 0.36533 seconds
Time After: 0.36696 seconds
Time Taken: 0.00163 seconds
SET lastactivity = 1780658702, location = '/forums/private.php?do=newpm&explain=1&u=108012', badlocation = 1
Time Before: 0.38586 seconds
Time After: 0.38615 seconds
Page generated in 0.38477993011475 seconds with 9 queries, spending 0.00876784324646 doing MySQL queries and 0.37601208686829 doing PHP things.
