Time Before: 0.00225 seconds
Time After: 0.00289 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00299 seconds
Time After: 0.00340 seconds
Time Before: 0.00371 seconds
Time After: 0.00384 seconds
Time Before: 0.00476 seconds
Time After: 0.00714 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00391 seconds
Time After: 0.01259 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01522 seconds
Time After: 0.01568 seconds
Time Before: 0.01851 seconds
Time After: 0.01974 seconds
Time Before: 0.01434 seconds
Time After: 0.02001 seconds
Time Taken: 0.00567 seconds
Time Before: 0.03025 seconds
Time After: 0.03039 seconds
Time Before: 0.03479 seconds
Time After: 0.03603 seconds
End call of global.php: 0.038687944412231
Time Before: 0.04071 seconds
Time After: 0.04089 seconds
Time Before: 0.04383 seconds
Time After: 0.04529 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108022', badlocation = 1
Time Before: 0.06423 seconds
Time After: 0.06454 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.063009977340698 seconds with 9 queries, spending 0.0079407691955566 doing MySQL queries and 0.055069208145142 doing PHP things.
