Time Before: 0.01384 seconds
Time After: 0.02231 seconds
Time Taken: 0.00847 seconds
Time Before: 0.02240 seconds
Time After: 0.02288 seconds
Time Before: 0.02315 seconds
Time After: 0.02327 seconds
Time Before: 0.02403 seconds
Time After: 0.02598 seconds
Time Taken: 0.00195 seconds
Time Before: 0.02332 seconds
Time After: 0.03030 seconds
Time Taken: 0.00697 seconds
Time Before: 0.04129 seconds
Time After: 0.04165 seconds
Time Before: 0.04425 seconds
Time After: 0.04545 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04053 seconds
Time After: 0.04571 seconds
Time Taken: 0.00518 seconds
Memory After: 2,261.703 KB
Time Before: 0.06596 seconds
Time After: 0.06608 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.40552 seconds
Time After: 0.40673 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.40891599655151
Time Before: 0.41702 seconds
Time After: 0.41719 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.42023 seconds
Time After: 0.42182 seconds
Time Taken: 0.00158 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=108066'
Time Before: 0.44193 seconds
Time After: 0.44230 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.44102311134338 seconds with 9 queries, spending 0.007556676864624 doing MySQL queries and 0.43346643447876 doing PHP things.
