Time Before: 0.01062 seconds
Time After: 0.01446 seconds
Time Taken: 0.00384 seconds
Time Before: 0.01458 seconds
Time After: 0.01510 seconds
Time Before: 0.01536 seconds
Time After: 0.01553 seconds
Time Before: 0.01642 seconds
Time After: 0.01881 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01561 seconds
Time After: 0.02314 seconds
Time Taken: 0.00753 seconds
Time Before: 0.02782 seconds
Time After: 0.02827 seconds
Time Before: 0.03080 seconds
Time After: 0.03202 seconds
Time Before: 0.02711 seconds
Time After: 0.03229 seconds
Time Taken: 0.00518 seconds
Time Before: 0.05624 seconds
Time After: 0.05640 seconds
Time Before: 0.06931 seconds
Time After: 0.07057 seconds
Time Before: 0.07659 seconds
Time After: 0.07681 seconds
Time Before: 0.07912 seconds
Time After: 0.08066 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108067' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.09714 seconds
Time After: 0.09748 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
