Time Before: 0.00164 seconds
Time After: 0.00214 seconds
Time Before: 0.00221 seconds
Time After: 0.00278 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00304 seconds
Time After: 0.00327 seconds
Time Before: 0.00413 seconds
Time After: 0.00667 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00336 seconds
Time After: 0.01002 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01359 seconds
Time After: 0.01398 seconds
Time Before: 0.01650 seconds
Time After: 0.01778 seconds
Time Before: 0.01115 seconds
Time After: 0.01796 seconds
Time Taken: 0.00680 seconds
Time Before: 0.02304 seconds
Time After: 0.02322 seconds
Time Before: 0.02515 seconds
Time After: 0.02644 seconds
Time Before: 0.02928 seconds
Time After: 0.02945 seconds
Time Before: 0.03141 seconds
Time After: 0.03283 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108074', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04557 seconds
Time After: 0.04584 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
