Time Before: 0.00339 seconds
Time After: 0.00423 seconds
Time Taken: 0.00083 seconds
Time Before: 0.00433 seconds
Time After: 0.00471 seconds
Time Before: 0.00493 seconds
Time After: 0.00504 seconds
Time Before: 0.00566 seconds
Time After: 0.00864 seconds
Time Taken: 0.00298 seconds
Time Before: 0.00508 seconds
Time After: 0.01206 seconds
Time Taken: 0.00697 seconds
Time Before: 0.01402 seconds
Time After: 0.01422 seconds
Time Before: 0.01668 seconds
Time After: 0.01810 seconds
Time Before: 0.01345 seconds
Time After: 0.01841 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02628 seconds
Time After: 0.02642 seconds
Time Before: 0.02899 seconds
Time After: 0.03025 seconds
End call of global.php: 0.032871961593628
Time Before: 0.03460 seconds
Time After: 0.03475 seconds
Time Before: 0.03747 seconds
Time After: 0.03904 seconds
Time Taken: 0.00157 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108081', badlocation = 1
Time Before: 0.05532 seconds
Time After: 0.05562 seconds
Page generated in 0.054373025894165 seconds with 9 queries, spending 0.0085132122039795 doing MySQL queries and 0.045859813690186 doing PHP things.
