Time Before: 0.00891 seconds
Time After: 0.01113 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01122 seconds
Time After: 0.01173 seconds
Time Before: 0.01203 seconds
Time After: 0.01222 seconds
Time Before: 0.01327 seconds
Time After: 0.01575 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01233 seconds
Time After: 0.02164 seconds
Time Taken: 0.00931 seconds
Time Before: 0.02598 seconds
Time After: 0.02636 seconds
Time Before: 0.02933 seconds
Time After: 0.03053 seconds
Time Before: 0.02522 seconds
Time After: 0.03074 seconds
Time Taken: 0.00552 seconds
Time Before: 0.05003 seconds
Time After: 0.05018 seconds
Time Before: 0.05825 seconds
Time After: 0.05950 seconds
End call of global.php: 0.061793088912964
Time Before: 0.06578 seconds
Time After: 0.06594 seconds
Time Before: 0.06854 seconds
Time After: 0.07000 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108090', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.08856 seconds
Time After: 0.08890 seconds
Page generated in 0.087331056594849 seconds with 9 queries, spending 0.0081250667572021 doing MySQL queries and 0.079205989837646 doing PHP things.
