Time Before: 0.00154 seconds
Time After: 0.00214 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00222 seconds
Time After: 0.00261 seconds
Time Before: 0.00287 seconds
Time After: 0.00302 seconds
Time Before: 0.00392 seconds
Time After: 0.00650 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00311 seconds
Time After: 0.01087 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01358 seconds
Time After: 0.01404 seconds
Time Before: 0.01550 seconds
Time After: 0.01672 seconds
Time Before: 0.01277 seconds
Time After: 0.01696 seconds
Time Taken: 0.00419 seconds
Time Before: 0.02262 seconds
Time After: 0.02277 seconds
Time Before: 0.02496 seconds
Time After: 0.02627 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02988 seconds
Time After: 0.03006 seconds
Time Before: 0.03218 seconds
Time After: 0.03368 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108095', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04659 seconds
Time After: 0.04682 seconds
