Time Before: 0.00150 seconds
Time After: 0.00200 seconds
Time Before: 0.00208 seconds
Time After: 0.00264 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00282 seconds
Time After: 0.00293 seconds
Time Before: 0.00360 seconds
Time After: 0.00616 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00298 seconds
Time After: 0.00956 seconds
Time Taken: 0.00658 seconds
Time Before: 0.01142 seconds
Time After: 0.01193 seconds
Time Before: 0.01337 seconds
Time After: 0.01458 seconds
Time Before: 0.01078 seconds
Time After: 0.01474 seconds
Time Taken: 0.00397 seconds
Time Before: 0.01949 seconds
Time After: 0.01963 seconds
Time Before: 0.02168 seconds
Time After: 0.02295 seconds
End call of global.php: 0.024587154388428
Time Before: 0.02635 seconds
Time After: 0.02658 seconds
Time Before: 0.02852 seconds
Time After: 0.02997 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=108098', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04218 seconds
Time After: 0.04247 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.041290998458862 seconds with 9 queries, spending 0.0083439350128174 doing MySQL queries and 0.032947063446045 doing PHP things.
