Time Before: 0.01498 seconds
Time After: 0.01923 seconds
Time Taken: 0.00425 seconds
Time Before: 0.01931 seconds
Time After: 0.01986 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02007 seconds
Time After: 0.02021 seconds
Time Before: 0.02094 seconds
Time After: 0.02320 seconds
Time Taken: 0.00225 seconds
Time Before: 0.02028 seconds
Time After: 0.02713 seconds
Time Taken: 0.00686 seconds
Time Before: 0.03409 seconds
Time After: 0.03450 seconds
Time Before: 0.03713 seconds
Time After: 0.03830 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03343 seconds
Time After: 0.03853 seconds
Time Taken: 0.00510 seconds
Time Before: 0.06685 seconds
Time After: 0.06698 seconds
Time Before: 0.08106 seconds
Time After: 0.08233 seconds
Time Before: 0.09100 seconds
Time After: 0.09114 seconds
Time Before: 0.09372 seconds
Time After: 0.09519 seconds
UPDATE session SET lastactivity = 1783244394, location = '/forums/private.php?do=newpm&explain=1&u=108120', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.11119 seconds
Time After: 0.11150 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
