Time Before: 0.01488 seconds
Time After: 0.01792 seconds
Time Taken: 0.00303 seconds
Time Before: 0.01802 seconds
Time After: 0.01857 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01887 seconds
Time After: 0.01901 seconds
Time Before: 0.01986 seconds
Time After: 0.02264 seconds
Time Taken: 0.00278 seconds
Time Before: 0.01908 seconds
Time After: 0.02694 seconds
Time Taken: 0.00786 seconds
Time Before: 0.03257 seconds
Time After: 0.03303 seconds
Time Before: 0.03590 seconds
Time After: 0.03709 seconds
Time Before: 0.03193 seconds
Time After: 0.03731 seconds
Time Taken: 0.00538 seconds
Time Before: 0.06372 seconds
Time After: 0.06385 seconds
Time Before: 0.07766 seconds
Time After: 0.07893 seconds
Time Before: 0.08625 seconds
Time After: 0.08640 seconds
Time Before: 0.08869 seconds
Time After: 0.09013 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108128', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.10632 seconds
Time After: 0.10657 seconds
