Time Before: 0.00994 seconds
Time After: 0.01340 seconds
Time Taken: 0.00346 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.01349 seconds
Time After: 0.01400 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.01425 seconds
Time After: 0.01441 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.01519 seconds
Time After: 0.01751 seconds
Time Taken: 0.00233 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.01448 seconds
Time After: 0.02303 seconds
Time Taken: 0.00854 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.02876 seconds
Time After: 0.02915 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.03042 seconds
Time After: 0.03166 seconds
Memory Before: 2,147.313 KB
Memory After: 2,147.172 KB
Time Before: 0.02805 seconds
Time After: 0.03193 seconds
Time Taken: 0.00389 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.523 KB
Memory Used: 133.094 KB
Time Before: 0.05427 seconds
Time After: 0.05441 seconds
Memory Before: 2,814.047 KB
Memory After: 2,814.563 KB
Time Before: 0.06488 seconds
Time After: 0.06612 seconds
Memory Before: 2,902.336 KB
Memory After: 2,902.930 KB
End call of global.php: 0.06825590133667
Time Before: 0.07343 seconds
Time After: 0.07359 seconds
Memory Before: 3,539.156 KB
Memory After: 3,539.586 KB
Time Before: 0.07574 seconds
Time After: 0.07720 seconds
Memory Before: 3,820.688 KB
Memory After: 3,822.375 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=108141'
Time Before: 0.09244 seconds
Time After: 0.09271 seconds
Memory Before: 4,298.742 KB
Memory After: 4,298.984 KB
Page generated in 0.091568946838379 seconds with 9 queries, spending 0.0079085826873779 doing MySQL queries and 0.083660364151001 doing PHP things.
