Time Before: 0.02446 seconds
Time After: 0.03072 seconds
Time Taken: 0.00625 seconds
Time Before: 0.03079 seconds
Time After: 0.03493 seconds
Time Taken: 0.00413 seconds
Time Before: 0.03621 seconds
Time After: 0.03684 seconds
Time Taken: 0.00062 seconds
Time Before: 0.03761 seconds
Time After: 0.04000 seconds
Time Taken: 0.00239 seconds
Time Before: 0.03690 seconds
Time After: 0.04387 seconds
Time Taken: 0.00697 seconds
Time Before: 0.05093 seconds
Time After: 0.05131 seconds
Time Before: 0.05392 seconds
Time After: 0.05515 seconds
Time Before: 0.05020 seconds
Time After: 0.05534 seconds
Time Taken: 0.00514 seconds
Time Before: 0.10092 seconds
Time After: 0.10110 seconds
Time Before: 0.11683 seconds
Time After: 0.11811 seconds
Time Before: 0.12602 seconds
Time After: 0.12620 seconds
Time Before: 0.12876 seconds
Time After: 0.13039 seconds
Time Taken: 0.00163 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108150', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14850 seconds
Time After: 0.14894 seconds
