Time Before: 0.00134 seconds
Time After: 0.00180 seconds
Time Before: 0.00187 seconds
Time After: 0.00233 seconds
Time Before: 0.00268 seconds
Time After: 0.00283 seconds
Time Before: 0.00354 seconds
Time After: 0.00567 seconds
Time Taken: 0.00213 seconds
Time Before: 0.00287 seconds
Time After: 0.00921 seconds
Time Taken: 0.00634 seconds
Time Before: 0.01091 seconds
Time After: 0.01130 seconds
Time Before: 0.01440 seconds
Time After: 0.01559 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01033 seconds
Time After: 0.01590 seconds
Time Taken: 0.00557 seconds
Memory After: 2,261.820 KB
Time Before: 0.02151 seconds
Time After: 0.02165 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02394 seconds
Time After: 0.02518 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.02811 seconds
Time After: 0.02824 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03029 seconds
Time After: 0.03175 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789069096, location = '/forums/private.php?do=newpm&explain=1&u=108160', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04472 seconds
Time After: 0.04513 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
