Time Before: 0.00455 seconds
Time After: 0.00699 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00706 seconds
Time After: 0.00755 seconds
Time Before: 0.00788 seconds
Time After: 0.00804 seconds
Time Before: 0.00886 seconds
Time After: 0.01161 seconds
Time Taken: 0.00275 seconds
Time Before: 0.00813 seconds
Time After: 0.01667 seconds
Time Taken: 0.00854 seconds
Time Before: 0.02130 seconds
Time After: 0.02173 seconds
Time Before: 0.02425 seconds
Time After: 0.02551 seconds
Time Before: 0.02060 seconds
Time After: 0.02577 seconds
Time Taken: 0.00517 seconds
Time Before: 0.03530 seconds
Time After: 0.03548 seconds
Time Before: 0.04158 seconds
Time After: 0.04290 seconds
Time Taken: 0.00132 seconds
Time Before: 0.04842 seconds
Time After: 0.04860 seconds
Time Before: 0.05135 seconds
Time After: 0.05283 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108180', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.07036 seconds
Time After: 0.07062 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
