Time Before: 0.00837 seconds
Time After: 0.01104 seconds
Time Taken: 0.00267 seconds
Time Before: 0.01112 seconds
Time After: 0.01169 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01191 seconds
Time After: 0.01203 seconds
Time Before: 0.01277 seconds
Time After: 0.01523 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01207 seconds
Time After: 0.01865 seconds
Time Taken: 0.00657 seconds
Time Before: 0.02257 seconds
Time After: 0.02304 seconds
Time Before: 0.02570 seconds
Time After: 0.02690 seconds
Time Before: 0.02191 seconds
Time After: 0.02710 seconds
Time Taken: 0.00519 seconds
Time Before: 0.03722 seconds
Time After: 0.03735 seconds
Time Before: 0.04415 seconds
Time After: 0.04536 seconds
End call of global.php: 0.047008037567139
Time Before: 0.05080 seconds
Time After: 0.05093 seconds
Time Before: 0.05288 seconds
Time After: 0.05429 seconds
SET lastactivity = 1788904690, location = '/forums/private.php?do=newpm&explain=1&u=108192', badlocation = 1
Time Before: 0.06953 seconds
Time After: 0.07036 seconds
Time Taken: 0.00083 seconds
Page generated in 0.068619966506958 seconds with 9 queries, spending 0.0085256099700928 doing MySQL queries and 0.060094356536865 doing PHP things.
