Time Before: 0.01478 seconds
Time After: 0.02047 seconds
Time Taken: 0.00569 seconds
Time Before: 0.02057 seconds
Time After: 0.02100 seconds
Time Before: 0.02128 seconds
Time After: 0.02147 seconds
Time Before: 0.02221 seconds
Time After: 0.02507 seconds
Time Taken: 0.00286 seconds
Time Before: 0.02152 seconds
Time After: 0.02997 seconds
Time Taken: 0.00845 seconds
Time Before: 0.03667 seconds
Time After: 0.03748 seconds
Time Taken: 0.00082 seconds
Time Before: 0.04000 seconds
Time After: 0.04130 seconds
Time Before: 0.03593 seconds
Time After: 0.04155 seconds
Time Taken: 0.00563 seconds
Time Before: 0.07197 seconds
Time After: 0.07213 seconds
Time Before: 0.08460 seconds
Time After: 0.08587 seconds
Time Before: 0.09545 seconds
Time After: 0.09561 seconds
Time Before: 0.09797 seconds
Time After: 0.09977 seconds
Time Taken: 0.00180 seconds
UPDATE session SET lastactivity = 1789119891, location = '/forums/private.php?do=newpm&explain=1&u=108201' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.11816 seconds
Time After: 0.11851 seconds
