Time Before: 0.01276 seconds
Time After: 0.01577 seconds
Time Taken: 0.00301 seconds
Time Before: 0.01588 seconds
Time After: 0.01633 seconds
Time Before: 0.01658 seconds
Time After: 0.01672 seconds
Time Before: 0.01753 seconds
Time After: 0.02007 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01678 seconds
Time After: 0.02429 seconds
Time Taken: 0.00752 seconds
Time Before: 0.02875 seconds
Time After: 0.02915 seconds
Time Before: 0.03162 seconds
Time After: 0.03282 seconds
Time Before: 0.02806 seconds
Time After: 0.03307 seconds
Time Taken: 0.00501 seconds
Time Before: 0.05351 seconds
Time After: 0.05366 seconds
Time Before: 0.06475 seconds
Time After: 0.06600 seconds
Time Before: 0.07326 seconds
Time After: 0.07347 seconds
Time Before: 0.07645 seconds
Time After: 0.07793 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=108225' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.09555 seconds
Time After: 0.09583 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
