Time Before: 0.00893 seconds
Time After: 0.01151 seconds
Time Taken: 0.00258 seconds
Time Before: 0.01159 seconds
Time After: 0.01198 seconds
Time Before: 0.01219 seconds
Time After: 0.01231 seconds
Time Before: 0.01320 seconds
Time After: 0.01620 seconds
Time Taken: 0.00300 seconds
Time Before: 0.01237 seconds
Time After: 0.01978 seconds
Time Taken: 0.00740 seconds
Time Before: 0.02502 seconds
Time After: 0.02542 seconds
Time Before: 0.02696 seconds
Time After: 0.02810 seconds
Time Taken: 0.00115 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02430 seconds
Time After: 0.02834 seconds
Time Taken: 0.00404 seconds
Memory After: 2,261.703 KB
Time Before: 0.04661 seconds
Time After: 0.04678 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05498 seconds
Time After: 0.05622 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.058406829833984
Time Before: 0.06155 seconds
Time After: 0.06169 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06412 seconds
Time After: 0.06553 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=108232', badlocation = 1
Time Before: 0.08210 seconds
Time After: 0.08239 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.080992937088013 seconds with 9 queries, spending 0.0083205699920654 doing MySQL queries and 0.072672367095947 doing PHP things.
